Please mention 4BTswaps.com when calling // Site Info & Advertise with Us
Go Back   Cummins 4BT & Diesel Conversions Forums > General Discussion Sections > Buildup Showcase Threads - All Engines, All Vehicles
Buildup Showcase Threads - All Engines, All Vehicles The place to display your diesel conversion project in progress or completed.
Reply
Thread Tools Display Modes
  #26
Old 04-29-2008, 10:47 AM
big specht big specht is offline
not much He is going to put a water/meth system on his truck and 14mm head and some differant injectors in it again and possible twins but you never know with him As for the housings you have are they all non wastgated????
  #27
Old 04-29-2008, 11:09 AM
racinwayne58 racinwayne58 is offline
waste gated.
__________________
93 RANGER 4BT COMPOUND TURBO'S HEAD STUDS FIRE RINGS SCHEID DIESEL PUMP AND INJECTORS
www.wrightsautoparts.com
  #28
Old 04-29-2008, 03:14 PM
we need non wastegated one's cause clearance issues
  #29
Old 04-29-2008, 07:35 PM
i'll look in the warehouse for some non gated housing's.
__________________
  #30
Old 05-09-2008, 09:56 PM
baron baron is offline
i just recieved my engine today and i have a few questions about your swap since it is the same basic truck i will be doing. what did you use for a tach signal? and you said you had your throttle cable made..... what kind of shop should i look for that does that? or is there kit available for that?
  #31
Old 05-10-2008, 10:33 PM
Ggg Ggg is offline
Senior Member
Quote:
Originally Posted by big specht View Post
That's a ATS tranny HAHAHA
I wish you good luck with the ATS and I really hope you don't need any after sale service. I have never owned an ATS but I have heard many a horror story about the lack of after sale service.
But then again all of the issues I am aware of were with automatics.
  #32
Old 05-11-2008, 08:05 PM
Quote:
I made the cable it is the stock one cut down I just cut the end off and pulled the cable out and used a cut off wheel to cut the cable to the lenght I needed and put the stock end back on to help to seal it. And used a sheath like what is used on a winch cable and crip on clamp to hold it cause the cable is stanless steel and I couldn't solder it. I will try to post some more pic soon
  #33
Old 05-11-2008, 09:02 PM
thank you for the help. glad i have someone who has already done the swap to learn from i am hoping to start in about a month on mine! cant wait to here more about yours as you progress
  #34
Old 05-12-2008, 09:06 PM
countryboy116 countryboy116 is offline
i was plannin on doing this swap with a ranger but i think ive decided to do it with my 97 F150 4x4, looks good cant wait till your done ill be basin my swap alot off yours it looks like haha
  #35
Old 05-19-2008, 01:00 PM
I will try to post some pics up this week it has been on the road for about 4 weeks now with no problems as of now the speedo is slow buy 10mph (differant tranny speedo gear) but we are figuring around the mpg in the high 20's to low 30's
  #36
Old 05-20-2008, 10:43 AM
mxman mxman is offline
Here goes the questions: What rear end ratio did you end up with? What engine RPM are you running at 60 and 70 mph (those are good mpg figures and I want to see if I can get my project close to RPM your running)? How is the power compared to your gas engine? Did you keep the stock radiator? Thank you for answering the questions.
  #37
Old 05-20-2008, 12:07 PM
3.55 gears stock radiator and I don't have a tach to know what rpm but it governs out at 85/90 mph as for the power We don't really know it was bought with a knocking 4.2 it was drove home and torn apart
  #38
Old 06-13-2008, 10:45 PM
any new updates on your project? how is it running?
  #39
Old 06-18-2008, 01:01 PM
Vito6 Vito6 is offline
Default Wow!
Great String! I have a 01 F150 SC with the 4.2l V6 and manual 5spd M5R2. What trans adapter did you use to mate the 4BT to the trans? Stock clutch? Did you retain the stock hydraulic slave/TO bearing setup? This 4BT looks like it sets back just like the factory V6. Looking fwd to new pics! Thanks. Dean
  #40
Old 10-22-2008, 01:15 PM
Sorry fore the late responce but we used the cummins/sb ford adapter. stock clutch and slave set up
  #41
Old 10-23-2008, 09:54 PM
how is the driveability of the truck and the fuel mileage any problems since the install
  #42
Old 10-24-2008, 09:19 AM
The truck rev's slow and seems gear bound in 1,2,3 4th and 5th are good we have never messed around with the pump yet it getting around 28 to 30ish mpg over all
  #43
Old 10-26-2008, 01:21 AM
wow that is some increadable fuel mileage i am shooting for twenty and i will be really happy with anything more than that. is there anything you would change so far or have needed to modify?
  #44
Old 10-26-2008, 01:26 AM
also what did you use for motor mounts
  #45
Old 10-26-2008, 11:14 AM
We used the p30 mounts and the liquid isolators . As for any thing we would change is making it rev quicker and change gearing for more topend (not for more speed just less rpm)it will top out at 80ish
  #46
Old 10-05-2009, 01:36 PM
Just a update. they only thing we did was to install the 3200rpm gov spring and change the gears to 3.27 . The gov spring is a must do mod . We haven't had any problem with. Mine is final in the shop to it's heart trasplant too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2006 - 2009 Shoumatoff Media, Inc.
