Please mention 4BTswaps.com when calling
// Site Info & Advertise with Us
| Isuzu 4BD1T/2T Topics related to the great Isuzu 4BD1T and 2T engines & related |
Thread Tools | Display Modes |
#1
Hey guys. I'm new here, but have been around on the IH8MUD forums for a couple of years. I have recently undertaken, or am attempting to undertake, the project of making an adapter for the 4BD2T to make it fit the A440 Transmission that is in my 1992 Toyota Landcruiser.
However, I have reached a point of indecision as far as what to do and I would like you guys to nitpick my reasonings apart. I have two options... 1- I can continue work on the adapter for the 4BD2T-A440. In addition to designing it and getting it made up, I would have to figure out how to get the torque converter mounted up, and make sure all the subsequent parts that connect to the torque converter would come out right. That would mean I would probably need a custom torque converter and stuff. Plus probably rebuild my transmission, etc. 2- I could take a 4HE1, which uses an Aisin AW450 transmission. This transmission is a close relative to, and in fact uses the same case as the Aisin 440 already in my vehicle, so the transmission would bolt in existing mounts. I would need to swap the output shaft from my A440, into the AW450 which some say is doable, and would allow it to mate to my transfer case. Facts: Isuzu 4HE1 is electronically controlled. How much? I don't know, some say only to turn on check engine light and modify fuel input at high temps so I don't know how complicated it would be to transplant. Also, the AW450 is electronically controlled. I don't know how to put it in and make it work since my A440 is hydraulic. Dimensions: 4BD2T- 813H X 660W X 810L and 340 Kg. 4HE1- 833.3H X 699.8W X 1181L and 365 Kg. So...based on what would work best for this particular set of circumstances, I want you guys to give me any comments, info, criticism, etc. Thank you, Michael.
#2
I would get a hold of the wiring diagrams for the 4he to see just how complicated it is or just wait and someone here will probably tell you.
I would just machine the adapter if it was me. I dont think it would be that hard to get one made up. Just measure everything twice and have it cut once to save on cost and all will go well.
__________________
Randy 67 Ford F100 sc/sb 2wd 4BD1T, 370cc injection pump & BIG custom injectors ( by Sheid Diesel), ARP head studs, custom equal length header, T56 6spd trans, 07 crown vic front suspension, 94 lincoln mark 8 IRS with 3.27 gears & limited slip, 4 wheel disc brakes ridin on 20's Still to come- Procharger D1SC & ball bearing turbo, 14 bolt solid axle, 4 link, 5R110 trans, etc |
#3
Carcrafter, I know what you mean about the adapter. I can draw that up no problem, but knowing exactly what needs to be done with the torque converter and all other pertinent parts is not something I really have experience with.
#4
Hey guys, some more info or the 4HE1. I haven't had time to wade through it all yet, many pages, but perhaps it will hold the answer to the question of how complicated the electronics on the engine are. Anyway...here it is http://lilaw.info/images/Manuals/LG4H-WE-9691.pdf
#5
Quote:
__________________
Andy Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel Misc. NPRs (4BD1T, 4BD2T, 4HE1TC) |
#6
Sounds good. Was it you who, in the 4BD2T thread, talked about having an A440 and AW450 that you were going to swap the output shaft out on? If so, did you find out if that was doable in such a way as to make the AW450 the HF2A TC?
#7
Yes, I talked about it but I haven't tried it yet. I've got an AW450 and "parts" FJ62 with the A440F but can't seem to find the time to pull the A440F and do a side-by-side comparison.
__________________
#8
I understand being short on time. I was under the impression that the cases were the same between the 440 and the 450. Can anyone confirm that? I think that the consensus was that the output shaft needed to be swapped from the 440 into the 450 and that is would bolt not only to the stock transmission location, but also the TC. Hopefully thats all true.
#9
I've followed this issue right from the begining and contributed to some of the speculation. To the best of my knowledge, no one on this forum or on IH8MUD has actually disassembled an AW450 and compared the component to those of an A440F. This is a perfect example of if enough people speculate on a subject it has a tendency to be viewed as fact!
I hope someday that the compatability between the two transmissions is proven to exist but at this point it is strictly conjecture and until someone actually goes through the physical comparison, it will remain just conjecture.
__________________
Andy Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel Misc. NPRs (4BD1T, 4BD2T, 4HE1TC) Last edited by astr; 09-11-2008 at 09:12 PM. |
#10
I am interested in this swap with the 4he1.... because the motor in my 93 fj80 is getting tired and will need replacement soon...
ASTR have you pulled the aw540 down to get the shaft out ??? I really want to know if this will work before I buy a box van for the motor and trans.... |
#11
Quote:
The NPR had less than 90K miles on it when it was wrecked. I just finished replacing the radiator and intercooler which were trashed in the wreck, got it running and did a compression check: 500# on all 4 cylinders! . I've got a couple more things to do to it before it is driveable like fix the brakes and remount the steering box. I think I will use the NPR as my test bed. It will be easier to try out the hybrid transmission in the NPR than the FJ62 as I the engine is already mounted and runable. The NPR is just a chassis with a busted up cab that will never be street legal but I can run it up and down the private road next to the office.
__________________
#12
Your NPR have a 33 Gallon side mounted tank on it? If so I'll take it off your hand$ ?
__________________
1947 Ford 1.5 Ton DRW Cummins 4BT 858 Ford ZF-S542 5pd Manual Slam Specialties Air Suspension The glorified semi-tractor to be used as a daily driver!?! |
#13
good luck on the swap let me know how you over come the starter on the trans of the isuzu trans it would be where most throttle pedals are inside the cockpit.
#14
Quote:
Why not just put that in your sig line?
#15
Quote:
The starter position is definitely going to be a problem. How much, I don't know for sure. The starter is located parallel to the transmission body, about the same height as the main body of the transmission, extends back about 5" past the bell housing/transmission body junction and adds about 8" to the width right where the gas pedal is located. Assuming that a hybrid transmission can be built, I see the starter location as the next biggest obstacle.
__________________
#16
Any idea what the capacity is for that tank?
#17
The dimensions are 24" w x 20" long x 17" tall so I would say it has a useful capacity of 33 gallons.
__________________
#18
Thank you.
#19
Hey ASTR. Thats a good deal. Congrats! What about just tying the 4HE1 to your A440? Could the torque converter from the AW450 be used? And mate that to A440?
#20
Quote:
The AW450, although electronically-controlled, is already matched to the 4HE1TC's torque characteristics. My guess is that is also designed and programmed for max reliability since it is used in trucks that can exceed 18,000# GVW whereas the A440F is programmed for softer, more comfortable shifts. As I’ve stated before, this is all speculation - a house of cards whose very foundation is in question. Except for the time, I have everything that I need to get some answers to these questions.
__________________
#21
Ha ha. Time...a priceless commodity. Well, whatever route you go, hopefully it works out. Myself, I have been looking into not only Rodneys extreme valve body, but an entirely rebuilt A440. He ramps up the internals, plus new valve body, and an entirely reengineered Torque converter that could be matched to the 4HE1's needs. I have a query into him on wether or not one of these rebuilt trannys would be ideal behind the 4HE1's 175 hp, and 350 ft/lbs of torque. I haven't heard back yet, but they said to expect up to two weeks before an answer. We'll see what he has to say. If you do get the output shaft swapped successfully that would probably be the best route to follow. Keep us posted!! Looking forward to your (hopeful) success.
#22
to adapt a 4hei i think the easiest way would be remakeke the rear cam cover and take the powersteering hole and make a starter that would go in that hole but i havent taken one apart and find otf it is possible or feasable. rod
#23
Quote:
Another possibility is to use the pto as a way to start the engine. I haven't verified it but it appears that the pto gear is always coupled to the engine. They use a clutch pack within the pto to engage and disengage the pto.
__________________
#24
all of the gear train is at the rear of these motors and the power steering is driven facing toward the back of the engine like 4bd1 and 2's starters are and you might have to hve a sprag drive i.e. one way bearing on the starter drive that would always turn when the engine is running so as not to have an enguagement problem wit trying to mesh or drive the cam gears as that is what the starter will be turning. if that could be done i would love to have one or the newer 5.2 for the power. if i ever get a junk one to play with im sure i could come up w/some thing to make it work. the computor is stand alone to run the engine i have a friend that works at an isuzu shop and i had him un plug things on a customers truck while in for service i.e. trans and chassis computor it threw a code but engine funtion was normal then he cleared the code . the injectors have an inverter drive and fire w/110 volt a/c so you will have to use a factory computor. rod
#25
Quote:
I may be wrong but the 5.2 (4HK1) uses a common fuel rail injection so each injector is electronically activated. This would imply that you need the computer for it to run. But why not just use the computer that comes with the engine. We've all gotten used to computer controlled fuel injection on gassers, so why not diesels? Ultimately, its a simpler system than the mechanical injection pumps that we all know and love. Another alternative for the 4HK1 is to use the IP from the 4HE1, if you could make the 4HE1 injectors fit the 4HK1 head. The two heads are definitely different as the 4HE1 has two valves per cylinder whereas the 4HK1 has four valves per cylinder but it might be possible to swap injectors. I think the pump drives on both engines are the same.
__________________
Andy Stock FJ62 SOA Samurai Tintop Ford E-350 4x4 Diesel M-29 Weasel Misc. NPRs (4BD1T, 4BD2T, 4HE1TC) Last edited by astr; 10-26-2008 at 02:24 PM. |
| Thread Tools | |
| Display Modes | |
