Please mention 4BTswaps.com when calling
// Site Info & Advertise with Us
| Buildup Showcase Threads - All Engines, All Vehicles The place to display your diesel conversion project in progress or completed. |
Thread Tools | Display Modes |
#1
I built this rig pretty much from scratch.
Here is the entire build thread of the rig if you want to see it. http://forum.ih8mud.com/hardcore-cor...ly-begins.html Bottom of page 31 is the rig as it stands today. It is now time for the stock 2F 6-cylinder engine H42 4 speed and Split Case T-Case to come out and a Cummins 4BTA/NV4500/Orion 4:1HD Tcase to go in. This site is a great resource of info and I hope to utilize it during the conversion. The top picture is from Moab were I met DieselCruiserHead in person for the first time. Thanks for all the of the assistance so far and in the future. Dan |
#2
I think you will be very happy with the new setup. cool ride!
__________________
2005 crewcab cheby 1500 slammed on 20s 1972 ford f350 cummins 4bt auto dana 70 4.10s rolling on 19.5s soon to be road worthy 1986 kabota hst7100 3cyl diesel yard worker and my toy, 1968 jd 112 with single cylinder diesel with stack running on veg oil!! |
#3
Started on it last night.
It took 2 hours to pull the old assy. That is from grabbing the first wrench to drain fluids to the assy sitting on the shop floor. |
#4
I stripped the 4BTA down and cleaned it up and painted it Cummins Red.
I stopped by Cummins West in Fresno and picked up new gaskets, front seal, thermostat, etc. I was a bit suprised how much this stuff is. |
#5
With some help from Bobs, I installed the new flywheel, Luk clutch assy and a new throwout arm assy with pivot ball.
I tightened down the clutch assy in 5ft lb increments. When I was going around on the 20ft lb setting, I began snapping the 5/16" grade 8 bolts. Bobs set me straight that the torque is 17ft lbs. ![]() I got it all together and the assy is 3" shorter than the assy I took out. |
#6
Did you fix the KDP ?
Looking good . Scott |
#7
Thanks for the heads up, I just found out about it this morning over on IH8MUD from two memebrs who are here as well.
I have not made the tab and installed it yet. |
#8
The motor mounts are done. I searched through the "Show Me You Mounts" thread several times before I made mine.
I'm staying with the angled configuration since I'm using Toyota 2F enigine mounts. Here is how the IP side turned out. I will be setting it in the engine compartment in a bit so I will begin to make the frame mounts. The frame rails are cleaned and the old mounts are removed. |
#9
Here is the Exhaust side.
Made sure there was enough room for the oil drain pipe and still be able to change the motor mount in the future. |
#10
I was able to get the assy swung into place.
The unsprung hieght of the top of my front bumper is 37 1/2". Kinda scary having that much weight that high in the air. |
#11
Having the same fitment challenges everybody on here that has done a conversion has had.
Front Driveshaft clearance Drain plugs Crossmembers Engine Mounts Shifter Steering Arms Exhaust routing Fuel tanks in the way etc. |
#12
Front steering looks good but the weight is still on the engine hoist, not the suspension.
#13
If I set the assy where I want it for the shifter and driveshafts, etc. The T-Case is sitting on the crossmember for the rear traction bar adn the drain plug is covered up. If I move it forward, the steering is very close.
There will be a 3/4" sweet spot, it is just a matter of finding it. No clearance issues with the firewall at all. |
#14
Made new frame mounted engine mounts and installed them.
The picture on the left also has an American Quarter in there for size reference. Last edited by D'Animal; 05-29-2009 at 09:48 AM. |
#15
KDP is done.
New main seal and wear sleeve (with adhesive) installed. |
#16
Front cover cleaned up and installed.
Pulleys and other Misc items going back on. |
#17
I'm very happy that my Wabco Vacuum pump and the Power steering pump cleared the bracket I made.
I have 2 1/4" between the aluminum gear case below the model plate and the power steering box. I really hope the engine does not jiggle that much when shutting off. |
#18
Looking great D'Animal!
I wish i could make those west coast trips with yall, maybe one day.... Any plans for a two-piece front driveshaft and oil pan mods? I know ive got to do either or possibly both to make my DS clear like i want. Motor mounts look great! and ive built some of my exhaust already and im running it behind the motor against the firewall and ive got plenty of room, im just worried about the excess noise and heat of doing so. We'll see.... Also, you plan to do any performance mods to that 4bta?
__________________
1974 FJ40 4BT cpl 858, VE Pump, 366 spring, KDPf, HY35w, SBC Con-O, NV4500, Dana 300, 4.10, 35s |
#19
My driveshaft fits great with no clearance issues other than maybe the huge drain plug if I roll the rig.
I'm using an FJ60 frame and have the 4x4 Labs Hi-Steer arms. The 4x4 Labs setup puts the arm behind the axle. the only way I will hit that is if I jump the rig and get really big air. I'm a firm believer that tractors are not built to fly. Before I do anything to the 4BTA, I'm going to see how it performs. It is suppose to be a 140hp model. if it moved a breadtruck down the road, it should move my rig down the road. I'm working on the rear crossmember now and here is how I did it http://www.4btswaps.com/forum/showthread.php?t=9216 Dan Last edited by D'Animal; 05-29-2009 at 09:18 AM. |
#20
Have you fully articulated your suspension yet? My front driveline angles looked very similar to your pictures. Remember, with the shackle at the back of the leaf spring your diff will move up and to the rear. Think beyond a static test to real off road situations where a little bit of bouce is a strong possibility. I found a little interference off road and in a panic stop mode, all fixed now, but I thought I was ok too until I tested it in a dynamic mode.
#21
Thanks for the idea. I have not fully articulated the suspension with the 4BT in it yet.
Quote:
I still have good clearance on the oil pan. It is actually better than it was with the 2F engine. I now need a long travel front driveshaft. When the front end is lifted, the driveshaft slide apart before the tires come off the ground. |
#22
Hey Dan a pleasure as always man! Also your Chevy is a work of art! Now, to work on that mileage
__________________
Diesel Converion Web Site Biodiesel Powered 1969 FJ55 Current Project in Buildup Stage Old 1971 FJ55, Sold M416 Military Trailer, Independent Suspension, Kitchen, Roof Top Tent 1999.5 Powerstroke, considering the future of... 89 & 91 Toyota Pickups '81 & '83 Mercedes Benz 300Ds 4BTswaps.com Administrator |
#23
Work on a bunch of little detail stuff today.
Everything cleaned and painted. Exhaust side Mounts are 100% done. Extra sensors removed and plugs installed Turbo installed. Oil lines Ran for Turbo. Air Pipe Installed Alternator Installed Oil filter installed. |
#24
If you are going make mounts like I did and use any of the back set of holes for the rear portion of the mount. The holes are deeper than the front and the threads are recessed, at least on mine.
I stepped up to 40mm bolts over the 30mm that I have in the front set of holes. |
#25
On the Injector Pump side of the motor.
Swapped out bolts in the rear of the engine mount. Installed oil line for the Wabco/Pump set up. Installed oil pressure line. Fabricated a Throttle cable bracket and connected throttle cable. Installed starter. Fought the power steering lines and decided to have new ones made. |
| Thread Tools | |
| Display Modes | |
