1 - 11 of 11 Posts
I finally found a worthy truck for my Isuzu. It's a 5.4 auto now with 140k. Bad engine. This likely won't be a very quick build because of the amount of electronics but let's get started.
127124
127125
Discussion Starter #2
In anticipation of this swap I pulled these at the junkyard last week. Research told me 97-08 used the same pedal/bracket assembly, so I yanked this from a more commonly manual 97 truck. Also grabbed the transmission wire harness, I'm not sure how much I can use but the connectors will be useful at minimum.
I didn't expect to find a loaded truck, so the factory adjustable pedals will likely have to go away.
127126
I did some measuring this morning. The ZF5 is ~29.5" long. The shifter is located ~14" from the engine mating surface. The auto in the truck is 33-34", hard to get a good measurement. I've seen it said that the ZF5 is 3.5" shorter, so that adds up.
So here's the dilemma. With the engine in the stock location, the shifter come out under the foot HVAC ducting, and the transfer case moves forward 3.5", meaning both driveshafts need to be modified as well.
The thing is I don't see how to get the engine back 3.5" to be in the optimal spot. I think 2" is doable, since the Isuzu is not as wide as the SOHC 5.4 in there now. A body lift might buy a little more room but I'd like to avoid more than an inch.
Still working a lot the last few weeks and haven't really touched the truck. That's slowing down next week so I can get a few hours in on the truck. I did block it up and crawl underneath today. Took a few measurements and pictures. So far it looks like fabrication will be minimal.
Spent about an hour today taking stuff apart, got the driveshafts dropped and almost ready to drop the t-case, just can't reach the top two bolts until I drop the trans crossmember. This truck is pretty much rust free but the crossmember bolts are being stubborn so I may as well soak them before I hit it again.
I picked up a 6.0L intercooler today, couldn't pass it up at $40. I know I can use it for my F350 at minimum but I checked the fit in the F150 for giggles.
It fits behind the grill pretty well but it's a bit too narrow to go in front of the a/c condenser. I think I could put it between the condenser and the radiator if I switch to a different radiator. I was planning to leave the stock radiator in but I do have a bunch of other ones around I could try out.
I do have a 3x12x24 aftermarket IC that will work easily if all else fails.
Discussion Starter #7
Drained the trans and t-case, removed the trans cooling lines and cooler, dropped the crossmember and the t-case. Just keep chipping away.
Damarble,
Can you create an adapter to move the shift arm mount further back? I ended up doing something similar when I put the RTO6610 in my truck only in my case the shift tower would have come out right in front of the seats. I did a little figuring on the angles and made a new low profile right angle shift tower that would fit in the tunnel. I then brought the shift arm up through the original hole.
Cj
Discussion Starter #9
I was thinking something like this if necessary. Once I'm able to set the new drive train in place I'll really have a solid picture, but keeping the shifter as far forward as possible is also desirable because I have the center jump seat and more leg room is good.
127266
Discussion Starter #10
I was reminded how fun it is to pull autos. That ZF5 will look much better here.
127288
Discussion Starter #11
I need to pull away from this for a little bit and finish up a duramax I bought to polish up and resell. But I did sell the auto trans today and rolled some of that cash into a near new MBRP 3" catback exhaust a guy has for sale locally. $150 for something that fits correctly seems like a no brainer. I'll only have to do a small custom section. I thought about reusing the stock 2.5" for now but nobody seems to think that's big enough for engines this size.
1 - 11 of 11 Posts
