So, ive been a member for a while, but mostly just lurking around and absorbing some of the info on the site.
i decided to share what i've done so far to my 1972 K20.
rough sketch of the initial plan.
6bt and manual trans swap.
restore the rest of the truck and modify as necessary. or as i saw fit. sometimes the line between necessary and my imagination get pretty foggy.
Anyhow, the swap is a little more involved than that, but ill let the pictures explain that.
I was given this truck by my grandmother, as my grandfather asked her to do after he died. that was in 1997. i was 13 then. i had high hopes of making this truck into a mudracer that i could still drive to HS and be a total ladykiller with. hahaha.
i intalled a huge all spring skyjacker lift, later model one ton axles and bought some big old MT tires. then i was strait out of money. The ol' man had installed a 5.7 buick diesel and a np425 4 speed. so the idea for the current phase of the project has a little to do with making the truck grandpa wanted. mostly its because i wanted it but the idea was all grandpa.
so, it was a gutless turd to say the least, but i drove it for a while trying to scrape some cash together to build a decent BBC for it. eventually just before i took off for college, i yanked the 5.7 and prepped to build a 454. i got so far as sending the order for my internals to Jegs with the check. they biffed the order somehow and never sent the parts or cashed the check. then i was at college and the poor truck got stuck in the most convenient spot at the time. eventually it landed in my dads barnyard. there it sat for 8 years or so. i robbed the tires when i was building my M715.
on labor day weekend of 2011, i decided it was time to collect my truck and start doing something with it. i bought a nice new trailer and hitched up the wagons. by this time i live in SW colorado, so it was a little over 1100 mile trek.
i removed the big lift and installed a more civil, less high school 4" before it went on the trailer.
this is the day before the haul back to CO.
installed it in the garage at home and got to work. slowly
got the frame blasted. somewhere in here, i horse traded with a buddy to have my garage wired for the air comp and welder in trade for some sub frame connectors in his dart.
