Hi Tim. Received your message. Anytime an injector bubbles, it's because the sealing washer isn't sealing correctly to the cyl head & cyl pressure & fuel is getting past the copper sealing washer.
In most cases it's due to the cyl sealing area is no longer a nice smooth surface. Whether rust, dirt or soot has contaminated the surface. Usually rust has eroded the sealing surface some. Some get lucky by just torquing the inj down an additional 5ftlbs or so. So instead of 42ftlbs, go to say 50ftlbs. If that doesn't seal it, you will have to pull inj & clean cyl bore bottom with a bore brush or in worse case a flat head screw driver.
