This is my 1991 GMC Sierra that I complete a Cummins 4BT swap, about 18 months ago. I used a 47RH transmission and modified the standard drive shaft, shortening the front section before the carrier bearing and adding the correct input spline. After having driven it for the past 18 months, I wanted to make some changes.
1: The turbo is a Holset H1C with a 16 cm exhaust housing and feels laggy and doesn't come on up on boost till the top of the rev range. I heard they made smaller housings but have not been able to find one yet. Any links would help.
2: The 47RH feels like it shifts too early within the rev range and I have to shift it on the column to get any power out of it. The fluid level is fine so I wanted to know if this was normal.
Here are the drivetrain brackets.
Here is how the engine fit.
And Marty thought it was MAAAAAAAAADDDD....
