Since I last replied I have lowered the PIS to open the 1st stages waste gate to 18 I have also lowered the gate on the second stage to 38 that required a little change it the stop on the 2nd stage gate to keep manifold pressure from dropping too much which just increases the boost creep above 2,100 rpm. Now I'm seeing 40 max at the manifold and it holds steady in 3rd, 4th and 5th I'm still seeing as high as 23psi from the 1st stage above 2,100 rpm if I hold WOT, however WOT in no longer needed to hold 75mph up my test grade which is 6% starting at 5,000' up to 6,500' it will hold speed unloaded with 2/3 throttle. Drive to manifold PSI is +/- 10% under normal loading and drive is ~20% over manifold while building boost and dead even under a steady WOT condition, I'm happy with this and even though 1st stage WOT boost is a little higher than I would really like whit things as they are I'm never there for any real length of time so I "think" I'm safe enough. At this point I'm up to nearly 16MPG from the 14.5 before tuning so a Win/Win in my book.
