I depends on how much work and money you want to spend , almost twenty years ago my family had a DD repair shop , and done a few 53 turbos , but it comes down on how much power you want , you already have the engine in the truck but just need a tad more just to make it have some get up and go or your going to carry and tow things , one the power wagon is kind of heavy but well built , you can just add a stock turbo and N65 injectors and that should give you the few extra pony,s to get out the way , that will not hurt anything because you are only using the extra power to get to speed , no towing , if you do want to tow something you will have to pull the head and upgrade some , that comes in two flavors , money and more money , one is a set of turbo liner kits that use the larger piston pin , yep you have to buy diffrent con rods , next is the crosshead kits , still you have to buy the crosshead con rods , those are the best , you could upgrade the can but you have to use new style valve springs and turbo valves , then you will have the same power as the 4-53 , my current project is a 3-53 out of a gama goat into a 2001 ford ranger , the truck is light so it perform well without a turbo , around 3500 lbs , what does the power wagon weigh ??
