heres a couple of my plans
well its all still in the works as the engine is hopfully going to the machine shop for a working over in the next couple of weeks. anywho. the block is getting bored .040 over to get rid of the scoring from 2 broken pistons rings. I am having them balance and blue print everything. Im still working on piston choice and have a couple of places working on cam options. The head is going to get ported and polished, I am going to use the hd valve springs for a 12v 6b(hoping to get aroud 3500rpm out of this engine) I already have a set 390 injectors and the pump is going to be sent out to industial injection at some point to be reworked with bigger dilivery valves. I plan to use an air to air ic, the hx35 that was removed from my 99 ram as a start(possibly twins if i can get enough fuel) and an nv4500 and plant the whole thing in either a cj7 or 80s model k5 blazer. Im in a similar boat as you on the finace thing but im hoping to have the engine done by the end of summer. anyway i have to get going but i will try to stay up to date on these posts.
