So I finally got my green J1939 connector wired in to my 2001 170 isb 3.9L motor and it doesn’t connect with Insite for some reason. I wired it as
A- chassis ground
B-constant 12v +
C-1939 signal Ecu pin 53
D-1939 return Ecu pin 52
E-shield Ecu pin 51
F-1708 supply Ecu pin 31
G-1708 return Ecu pin 30
I have verified continuity and ground. My buddy had to use an adapter to connect to the green J1939 plug.. Any ideas? Below is the diagram I used for my wiring.
A- chassis ground
B-constant 12v +
E-shield Ecu pin 51
