1 - 7 of 7 Posts
350 Ram Jet for sale. Has 20,000 miles its installed in a k5 blazer right now. The 700r4 tranny is smoked and my dad is too lazy to fix it. He was asking 5200 for the whole deal. I think is fair because the motor is broke in and you will have all the parts you need for your conversion or just switch bodies. Anyway you will get the Doug thorly headers those are 600 bucks alone. You will have the radiator, fuel pump, all the gauges, a/c, 35x12.50x15 m/t tires on some nice alloy rimes. The blazer has like a 3 in lift.
Let me know what you think
Specifications
• 350 HP @ 5200 RPM
• 400 ft/lbs torque @ 3500 RPM
• 9.4:1 compression ratio
• Cast iron 2-bolt main block
• Cast iron crankshaft
• Hypereutectic Aluminum
• Powdered metal steel connecting rods
• Cast iron Vortec cylinder heads (1.94" Int/1.50" Exh valves)
• Hydraulic roller cam
• Camshaft Lift: .431 Intake / .451 Exhaust
• Camshaft Duration @ .050 : 196° intake / 206° exhaust
• 1.6 ratio aluminum roller rockers
• Aluminum intake manifold
• 8'' torsional damper
• Long water pump
Discussion Starter · #2 ·
If you want just the motor I can sell it for $4000
I think so too, 4k will build quite a small block (or even buy you a turn key crate motor), I think you're gonna have one heck of a time getting rid of it for that, but good luck to you.
D.
1 - 7 of 7 Posts
