1 - 6 of 6 Posts
Detroit Section Caretaker
Spicer 3000 series were also common.
And Allison automatics.
Most anything available with an SAE #2 or #3 clutch housing will fit or can be made to fit.
I have a fresh rebuilt Spicer CM-5052-C 5 speed direct transmission (SAE#2), clutch and pressure plate from behind a 4-53T if you are interested. I will also be heading towards Excelsior Springs Missouri in the near future....I rebuilt it with plans on using it in my truck. Shortly after I finished the rebuild I found a 10 speed roadranger which I am currently using behind my 4-53T.
Chris
Part of your decision on what trans to use should be based on the weight of truck and common loads. If in a light weight vehicle(Jeep?) a 5 speed, close ratio trans(540) would suffice, a heavy vehicle might find a RR 10 speed more useful. Best fuel efficiency is at the torque peak(1700-1800 RPM) so final drive ratio, including OD trans. ratio should be about 3:1.
Ed
1 - 6 of 6 Posts
