1 - 6 of 6 Posts
Hello everyone.
I wanted to ask where I can get an engine adapter plate for a 47rh to 4bt? I found a post with a part number but I can't find anything with that part number.
Thanks,
Eugene
The engine adapter you need is from a Dodge truck 94 - 01 from a auto or manual.The rear of the block on a 4bt and 6b are all the same .
The form has all this info ,has been talked about .Take some time and search and buy a star ,it will pay you back with all the info that here.
CrewCab59
Thank you. I did do some searches and I did find that bolt pattern are the same for 4/6bt as you stated. I guess I'm should clarify and that is where can one buy the adapter. I know I can hit some salvage yards but I was more interested in shops what will have these on hand. I'd called cummins south plain and they couldn't help.
Thanks,
Eugene
Thanks,
Eugene
The adapters can be found on Ebay from $50 -$175.00 all depends on time and the amount pf people needed them.
1 - 6 of 6 Posts
