Hey y`all
I am planning to do a swap in my 98 Explorer. I will of course be putting in a 4BT and I have a 47RH to go in behind it. Will I need to find a computer from a donor to operate this transmission or will it work without one? Are the shift valves operated by pressure only or are they sensor and PCM controlled ? Any informational help or direction for transmission swap references I can I can find from the memebers here will be greatly appreciated.
Thanks to you all.
Thanks to you all.
