Hello
Recently re-built a 4b 3.9 (1989) off a Morbark chipper.
I had good oil pressure 35-45 lbs after overhaul and it runs great. Total overhaul with new pistons, bearings, etc.
I had a small water leak coming from the oil filter/cooler housing.
So, I went to Cummins and $50.00 later, came out with two new cover gaskets.
Immediately after start up i had oil pressure (cold engine). After warming and throttle up to 1500 and then at 2200 RPM (warm engine), I throttled down and the engine died as the low oil pressure gauge circuit did its job when the engine oil PSI fell below 20 psi.
I now have low oil pressure. At idle, 15-18 psi and at 1500 rpm, maybe 25-30. Very different from my readings before I changed the gaskets.
I noticed that my housing does not have a bolt in the lower tip of the cover. Meaning I have 14 bolts instead of 15.
I did not look at the old gaskets or compare. At a glance they looked identical and both sets were original cummins parts. Any help is appreciated.
Is there different covers or gasket part numbers that could block or obstruct an oil port?
