1 - 3 of 3 Posts
Ok, so I could not find the thread where I thought I posted oil pan info, but here is a new thread to add to the stickies instead of just replying to a pre-existing thread. Would one of the moderators please add this to the 4BT Technical Topics Index under "Oil Pans" in Post 9? If anyone else has oil pan info such as "Dry Sump" would you please get the moderators to add it to the Tech Topics Index as well?
First, here are the part numbers I know - they are not current, but were in the original parts books - and someone else can pitch in other numbers below:
Catalog Bulletin No. 384232 Date 4/88
4BT CPL 730, 763, 767 & 4BTA CPL 594
Rear Sump:
3907570 Pan, Oil
3905206 Connection, Oil Suction (Oil pick up tube)
High Level 10 quarts
Low Level 8 quarts
Heater 22mm exhaust side
Drain exhaust side
Catalog Bulletin No. 3672121-01 Date 3/98
4BT CPL 2302 & 4BTA 2109
Rear Sump:
3901049 Pan, Oil
Low Level 8 quarts
Drain exhaust side
Front Up Angularity (Deg): 45
Front Down Angularity (Deg): 45
Side to Side Angularity (Deg): 45
Non-Isolated
Suction tube flange thickness 5.16mm
Shallow (Center) Sump:
3907570 (mine was marked 3901227Pan, Oil
3905223 Connection, Oil Suction (Oil pick up tube)
Low Level 8 quarts
Heater 22mm fuel pump side
Drain fuel pump side
Cannot use immersion heater with balancer
Note: I turned my pan to drain on exhaust side
Non-Isolated
Front Sump:
3932133 Pan, Oil
3920795 Connection, Oil Suction (Oil pick up tube)
3932138 Gasket, Oil Pan (Isolated)
3932430 Isolator, Noise
3900631 Screw, Hex Flange Head Cap M8 x 1.25 x 25
Low Level 8 quarts
Isolated
Suction tube flange thickness 6.35mm
As far as measurements go:
Drain plug max depth = 6.5"
Sump depth = 6"
Sump length = 6.5"
Depth at ends = 4.75"
Front / Rear Sump:
Drain plug max depth = 7.5"
Sump depth = 7"
Sump length = 8"
Depth at opposite end = 2.75" (approximately)
Hopefully this helps answer some questions.
Patrick
I figure that most of those part numbers have been obsoleted by now. Seems like every time Cummins raises a price on a part they also obsolete the old part number.
1 - 3 of 3 Posts
