Now for the big mess. The fuel lines. Starting at the lift pump, that unit should be OK with the P7100 and the fuel lines leading up to the fuel filter unit. Should look something like this diagram.
Next is the fuel line leading to the injection pump.
1. 68152 Clip
2. 3093923 M8x1.25x14mm Flange Head Bolt
3. 3918192 Seal (2 required)
4. 3921333 Tube Brace
5. 3924725 Banjo Bolt M14x1.50x26mm
6. 3903315 Banjo Connector
7. 3911447 Banjo Connector
8. 3923527 Hose Clamp (2 required)
9. 3929785 Hose
Now the fuel drain from the injection pump.
1. 3900626 M6x1.00x12mm Flange Head Bolt
2. 3921652 Fuel Drain Tube
Now the air/fuel control plumbing.
1. 3900589 M8x1.25 Flange Head Hex Nut
2. 3902662 M10x1.50 Flange Head Hex Nut
3. 3910265 Male Elbow
4. 3991034 Plain Hose
5. 3938056 Plain Hose
6. 3920348 Clip
7. 3920719 Hose Clamp (4 required)
8. 3920803 Male Connector
9. 3930789 Street Pipe T
10. 3991513 Air Fuel Control Tube
11. 3927317 Elbow Hose Coupling
12. 3287128 Air Fuel Control Tube
Now, on the fuel filter diagram there is a special banjo bolt which has a bleed screw in it. You may or may not have this but I'll give you the numbers anyway. Here's the diagram.
1. 3925954 Filter Head Adapter
2. 3286503 Fuel Filter (Fleetguard FS1251)
3. 3963983 Sealing Washer (2 required)
4. 3911446 Banjo Bolt
5. 3939570 Captive Washer Cap Screw
Now comes the rats nest of injection lines and braces. You may have some of this with your existing lines but I'll list all the parts just in case.
1. 4942278 Banjo Seals (4 required)
2. 3905307 Banjo Bolt M6x1.00x14.3mm (4 required)
3. 3918109 M8x1.25x25mm Flange Head Bolt (2 required)
4. 3918188 Banjo Sealing Washer (2 required)
5. 3924726 Check Valve
6. 3927633 Fuel Manifold
7. 3904711 Tube Brace (2 required)
8. 3917717 Tube Brace (2 required)
9. 3917746 Vibration Isolator (8 required)
10. 3918784 Tube Brace
11. 3918785 Tube Brace
12. 3918786 Vibration Isolator (2 required)
13. 3920414 Tube Brace (2 required)
14. 3920854 M5x.80x24.5mm Captive Washer Cap Screw
15. 3928506 #1 Fuel Injection Line
16. 3928507 #2 Fuel Injection Line
17. 3928508 #3 Fuel Injection Line
18. 3928509 #4 Fuel Injection Line
Next diagram is the fuel shut of solenoid. Your pump may or may not have this and sometimes they are located differently. Should you desire, you can eliminate this item and control the pump with a manual cable. That is the way many farm tractors are done. Also eliminates one more electrical circuit.
1. S600 1/4" Lock Washer (2 required)
2 3902023 M6x1.00x25mm Flange Head Bolt (2 required)
3. 3910959 M6x1.0I0 Lock Nut (2 required)
4. 3919182 Shut Off Valve Lever
5. 3934972 Shut Off Solenoid (This part shows to be obsolete)
6. 3919449 Cotter Pin
I checked a more recent serial number 45822898 and it has a revised diagram. They show a bunch of different solenoid numbers depending on the vehicle it was used in. Here is that diagram.
1. S600 1/4" Lock Washer (5 required)
2. 146157 1/4" Plain Washer (2 required)
3. 3901937 M6x1.00x45mm Flange Head Bolt
4. 3902023 M6x1.00x25mm Flange Head Bolt (6 required)
5. 3910959 M6x1.00 Lock Nut
7. 3919452 Solenoid Bracket
8. 3922832 Shut Off Lever
9. 3934972 Solenoid
Note: The following info is provided about the solenoid. Ford used 4089576, Blue Bird used 3800777, 4bt horizontal mount used 3800687, and 4bt vertical mount used 4089574. So that last number would be for the vertical bracket as shown in both these diagrams. If you happened to have the horizontal bracket on your pump it would be the other number.
Well, that's about all I can do for the plumbing. Hopefully, I didn't type any of the numbers wrong.
Now for the fuel injectors. The standard CPL 1839 injector is part 3802547 for new ones or 3802547RX for rebuilt units. New ones from Cummins cost $265.55 each. Ouch! Rebuilt ones at $215.15 each aren't much better. I believe the Bosch part is 0 432 133 861. You'll need to look a bit but you can find those pretty cheap. Those are 5x.010 tips. For 250 HP you need a 5x.012 tip injector. You can find these in the $80-100 range. Popular upgrade size for the '94-98 Dodge Cummins with the P7100. For the pistons and rings the Cummins part for that kit is 3802562 per cylinder in standard bore. There are tons of those out there in the aftermarket. Usually around $100 per hole plus or minus a little.
