1986 or 1987 ?? NPR trucks that came with the GM automatic came from the factory with an adapter and dual flywheel setup that made the back of the engine look like the back of a Chevy. That's what I used and then an Advanced Adapter bell housing and clutch setup (chevy to Toyota kit). Downy made a kit as well. Kind of a rare find to run across an 87 NPR automatic these days.
That's the setup I did. Adapter, Isuzu manual flywheel, spacer, Gm flywheel, AA bell housing, H55. As far as an FJ60 goes, the added space of the adapter worked out well to keep engine off the firewall without doing driveline mods. I think the Almares kit put the engine right on the firewall.
1987 BJ75
the NPR I came across is a 1989 with the MSA5D manual. Body is shot leaf spring mounts arent connected to the frame anymore, frame is rusted in half in more than one area. BUT... that engine starts with a crank of the started and transmission feels great. So I bought it for $2500 and drove it 700 miles from Kentucky to North Carolina. Absolutely terrifying drive but it made it nonetheless. Cosmetically ruined but mechanically perfect.
410+ PSI in all cylinders
I'm excited to take on this swap. I think I may try to keep the Isuzu bell housing along with the engine, make an adapter plate for the Isuzu bell housing to H55F transmission alone. Use a 13BT clutch for the added power from the old 3B motor that was in the troopy and hope that the 13BT clutch will work together with the Isuzu pressure plate and flywheel!
If anyone has any recommendations or thinks this has no way or working please let me know! Trying to learn the most I can so if someone has experience that I don't I'd love to hear it. Never swapped a non-toyota engine into a Toyota, all new way of thinking about things
Here's a video I took incase the swap loses momentum and I need to sell the engine/tranny, engine cold start at 1 minute
