The design of the HE221 compressor impeller is toward more radial blades, which improves air flow, and PR at a cost of lower efficiency (more heat).
Yep. As Bush65 said. It basically throws air harder but less efficiently.By boost capacity you mean can run higher boost?
Sent from my SM-G930F using Tapatalk
The HE221 is a TD04HL based turbo and others have swapped housings. I would go for a 5cm which I don't think you'll find with T3.Sorry if this is in the wrong section but I was searching HE221 / TD04HL / HX30 and came across this thread.
I have a OM617 with an M pump (7.5 elements) and recently finished up installing a HX30 turbo. With the HX30 boost comes on after 2k RPM's. I would like something that comes on sooner.
I am looking at either a HE221 or TD04HL.
My main question is could I use an HE221 and change the turbine to a Volvo 6cm? That way the Volvo mount is easily adaptable to the T3 of the Mercedes exhaust header. Mamba also sells the 3 bolt/hole exhaust plate that I could weld a V-Band to.
I'm hoping the CHRA and front of the Holset HE221 would be similar enough to the HX30 that I wouldn't have to reconfigure too much. The TD04HL's that I can find have a water cooled middle that I would prefer not to mess with.
Any insight would be appreciated and I can post in the OM617 if that is preferred. Thanks!
Many thanks DougalThe HE221 is a TD04HL based turbo and others have swapped housings. I would go for a 5cm which I don't think you'll find with T3.
Water cooled centre housings can be left not connected with no issues. Just don't seal them up.
For turbo spec, the 9 blade turbine is not ideal. The 11 blade (harder to find) is best and the 12 blade is second best. The 9 blade is for high rpm ricers with lots of exhaust flow running low boost. We're the opposite.Hi
Am having problems with boost on a isuzu 4BD1T in my 6x6 perentie.
Have fitted a TD04 HL 19T with 6cm housing and 9 blade turbine
Exhauxt is 2.5” to muffler & 2” from muffler back (yet to be upgraded)
At the moment cannot get more than 10 PSI of boost under load/full throttle
Testing to date:
Fitted boost gauge (in compressor outlet next to WG sense port)
Fitted exhaust pyro in manifold adapter prior to turbine.
Wound out max fuel screw on side of pump, getting 750oC at full load at 10PSI and black smoke when first accelerating
found that donaldson filter service indicator was pulling in and removed airfilter inlet hose that runs from under RH guard which stopped the service indicator pulling down.
Tried running with no ducting,filter on compressor housing – still only 10 PSI boost
Tried running with only 2.5” dump pipe fitted – still only 10 PSI boost
Tested boost gauge with mitey vac and tested up to 15 PSI boost ok
Inspected WG and is seating ok, fitted shop air and WG starts to open at 15 PSI
Removed exhaust pyro and fitted pressure gauge – 15 PSI exhaust pressure at 10 PSI boost pressure under load
Truck drives ok (havent been able to put a load on the back but unloaded going up the test hill seams to pull ok) but thought I should be getting better then 10 PSI out of the turbo???
Bob
Here's what I think they can do with a monster intercooler at 18:1 A/F. This is 30psi sealevel which puts it just off the top of the map at PR3.Thanks Dougal, you know much more about these turbo's than I.
I still maintain they are not the best match for a heavy 6x6 Perentie (5600 kg gvm, 7100 kg gcm) that has a wider and higher body than Defender, with poor aerodynamics, high driveline losses and low overall gearing (no overdrive 4.77:1 diffs), so engine working hard around max rpm all day on the highway. That's a bit different to many of us here that rarely exceed 2500 rpm.
I bought my used HX30w from XHC Turbos on ebay. Look in the last picture of the page where they detail the intake wheel size.There is definitely more HX30 turbo chargers around. Problem is specific information such as wheel diameter is rarely provided. I've asked and no luck. Regarding an HX30 with a 6cm2 exhaust housing AND 44mm or 46mm intake. Determining the housing is pretty doable however, getting information on wheel sizes is going to be next to impossible. Does anyone have a part number(s) that would indicate the intake wheel is 44 or 46mm for a Holset HX30?
Thanks for any help,
Jeff
