1 - 17 of 17 Posts
Michael, I just happened to be searching around by the filter size thread and came a cross this. The only thing that I saw was the oil filter od size compared to the Isuzu size filter.
Wix 51673(spec in picture) is the smallest filter I found but I don’t have the space.
126946
Discussion Starter #8
So according to the specs for the oil filter wix 57521 off the 4he1 motor the oil filter adapter should fit? That motors filter head.
The 4bd and 4HE filters are interchangeable, so if it works on one, it ought to work on the other. Are you going to be a Guinea pig for all of us?
Discussion Starter #10
Well I may have to because I don’t have room for a filter. But I have to wait a few weeks to have funding. Only down fall is I can test fit but not pressure test(not at that stage). Lol.
I’d say test fit, if it looks good fire it up and crawl under. If it’s leaking you can shut it off in time, no worries.
Discussion Starter #16
No updates, I had a little bit more struggle on getting the body to fit around the transmission and motor. So I haven’t ordered it. I did notice that I will have to cut the bottom end of the screw portion of the filter housing down to were the threads start. I will let you know when I get there. Joe
1 - 17 of 17 Posts
