Can I take the A/C Compressor bracket/water inlet off a Dodge Cummins and put it on my 4BT CPL858???
not alot of belt contact on your alternator, i would be worried about slippage although an alternator shuoldnt be hard to driveCheck out my website. It shows my Jeep with the A/C installed.
Yes I did change it. I also just finished changing under the hood again. I inverted my Exhaust manifold like it should be and use the Freightliner a/c / alternator mount. I will try to post some pictures soon.not alot of belt contact on your alternator, i would be worried about slippage although an alternator shuoldnt be hard to drive
nevermind I seen later that you changed your alternator location, that is likely the reason for the squeling
I think the alternator is the hardest to drive, other than the A/Cnot a lot of belt contact on your alternator, i would be worried about slippage although an alternator shouldn't be hard to drive
