I have a non running 4bt for sale $2250.
Bought it and didn't get around to using it and found it was "frozen". Pulled the head and found the rings rusted to the cylinder walls. It does turn over now. pulled mains and rods, no spun bearings. It needs an overhaul.
It comes with custom engine mounts that use first gen Dodge isolaters and front pulley set up with AC pump. The AC pump is a core.
If you don't want the Dodge setup I have fan setup that came with it, I'll remove the Dodge mounts.
I have a frame to hold the engine for transport. I also have 2 other thersmostat housings that can be use with the Dodge set up, pick the one you want.
You must pick up, SE Arizona.
