Hi all,
First, thanks for this site. I'm just starting to get to the engine/trans part of my build and will certainly be asking a bunch of questions. I have a 4BT from a Ford Wonder Bread truck.
The main questions I'm looking to answer are:
1. Which 2WD automatic trans to run? I see comments that the 700R4 is a poor choice then I see it isn't...
The only thing I'd ever tow - if I tow at all - is a couple motorcycles. Figure less than 2000 lbs total, including the trailer.
2. What RPM should I be targeting for freeway cruise? I'd like to maximize mpg but not at the complete expense of some level of 'getting out of its own way'.
3. Is there a 'standard' set of mods that I should be looking at? Near as I can tell, I do an HY35 9cm, 3K spring kit and tweak the fuel screw a bit. I want some improved performance while retaining reliability.
4. Any recommendations for suppliers of the 'factory' power steering pump assy and an A/C condenser mounting bracket?
5. Anyone converted to WVO? Can you share learnings, do's and don'ts?
Also, I'm posting the build thread for the rest of the project here. Take a look if you're interested in seeing how Carbon Fiber can be incorporated into a 55 year old, diesel powered hotrod Suburban!
http://67-72chevytrucks.com/vboard/showthread.php?t=249457
I appreciate any guidance y'all can provide. Thanks and drive safely,
Chris
Chris
