do you already have an inline pump already and its toast? if you do then a rebuild would be aroun d $1200 -1500 a bench test alone is $150 if not then remember you will need new lines, new front gear and timing cover as well new injectors as the pop off pressure for inline pumps is higher than for the old ve's
a used core should be 400 remember delivery valves and cylinders as a set on the p pumps are not cheap cost more than $400 and they are about the only thing that gums up and gives up especially with WVO running through them, but once they get into the pump replacing the plungers, delivery valves cylinders and all the springs ect in the p pump parts alone get upwards of 600 - 700 real quick on a 4cyl pump then add time, they rarely fail if you have a pump bought as a core, be sure it came off a turbo'd rig and not a NA, if its off a NA walk away there is no boost fueling advance. Air fuel control (AFC) diaphram otherwise for $400 id buy it and put it on yours in place of the current in-line if yours is gunny bag.
the inline pumps are sometimes refered to as million mile pumps so id check other things before looking at it as failing. most common thing that goes out and people thinki it is the pump is the fuel overflow valve. $50 part that keeps 30-40psi of fuel in the pump before it enters the plungers to be pressurized going to the injectors, if it drops in pressure the pump acts weak and the system starts failing to perform but even if it fails entirely rarely does the pump itself fail
