1 - 7 of 7 Posts
Hey, im new , and ive been searching all over this forum, maybe not enough, but im just gonna start a new thread cause i cant seem to find exactly what i need.
I am doing a 99 tahoe conversion. 5.7 to the 4bt. So i need help on knowing everything i need.
So far i know i need the adapter , transmission controler, engine mounts. Is there anything else??
it have been done before, so you can find detailed conversion threads with pictures to help you... but as far as i remember right now you will also need a vacuum pump for the brake lines and mounting brackets for power steering and a/c compressor...
1; what tranny is in the Tahoe, if there is a direct mount FW hsg and flex plate available, use it, it will be shorter than a sae to automotive adapter set.
2: what ratio is the tahoe axle(s), is it 4WD?
1 - 7 of 7 Posts
