1 - 2 of 2 Posts
Can anyone identify part numbers for the long tube dipstick for the 4bt? (This image was sourced from the interwebs so may be from a 6bt. don't shoot me if its not the correct one.) Assume it should be almost identical to a 6bt but slightly shorter for the 4bt.
131456
Cannot help directly with 4 BT numbers.
Are you looking to replace the standard stick?
If so there should not be much of a problem changing it out, just have to adjust the marks on the new stick to match the level as set by the original stick.
Cheers Steve
1 - 2 of 2 Posts
