OOPS Miss post...............
Where did it need to go? Sorry new hereOOPS Miss post...............
Yes sir the kids do make it worth it and stuff like this makes them want to learn.Shifter would be one of the last things I'd worry about, minor weld/blacksmith job to make ergonomics work.
Great class project by the way and mu Respect for sharing it wit the "Kids" My shop has always been open to anyone that had the gumption to want to "Build it not Buy it".
5 of the people that passed through my little home shop used what was learned there to get their feet in he door of a shop and made a base for spouse, kids and house,
I spent 40 years as a machinist involved with some amazing projects but those 5 "Kids" were my greatest achievements I made for my Trade.
Where does your engine sit? If you measure the front of your frame to the timing case of your 4BT how far is it back?I am in the middle of a very similar project('84 CJ7/early GM NV4500/D300) and I set mine back approximately 3". I am using a fiberglass body on custom mounts but it is in the same position relative to frame as stock. Planning to fab a custom floor plate to replace the stock one that moves the shifter holes back.
My Jeep was originally a 258/T4/D300 - I am using an Advanced Adapters bellhousing and transfer case adapter with the new setup and rear driveshaft length will only decrease about 1".
I looked through my photos and can't find anything that shows the distance from the front of the frame. I'll take a measurement when I get back to the shop - unfortunately, it's 20 miles from my house and I don't get there every day.This is what I am looking at basing my measurements from.
Did you add an intercooler? The mounts from Farm Strong Inc will offset to the drivers side 1" also.I looked through my photos and can't find anything that shows the distance from the front of the frame. I'll take a measurement when I get back to the shop - unfortunately, it's 20 miles from my house and I don't get there every day.
My engine is offset 1" to the driver side.
My engine is 120HP CPL 857 with air/water aftercooler - may switch to air/air later.Did you add an intercooler? The mounts from Farm Strong Inc will offset to the drivers side 1" also.
How did you run that set up? I was going to do air to air but would have to knock the engine back 3.5" which is not a problem but when you go back the frame rail goes down. So not sure if I will run into trouble if I don't bring the engine back up.My engine is 120HP CPL 857 with air/water aftercooler - may switch to air/air later.
How does that setup run? Engine Temps?View attachment 135984
The aftercooler I have is the stock Cummins setup - sits on the intake manifold and uses engine coolant for the liquid side.
(engine setup shown in first pic is before installing the Advanced Adapters D300 adapter - stock GM 32 spline shown.) View attachment 135984 View attachment 135985
Where do the hoses plug in to for that on the engine?Since mine is a long term project I don't have operating experience with the engine(just test run). But from what I have read this setup is an improvement over non - IC engines, but not as good as a properly sized air to air - mainly because of the physical size of the cooler and the temp of the cooling medium.
Many of the older design Cummins powered big rigs utilized this design, as well as a lot of industrial/stationary Cummins equipment.
4BT Aftercooler help
Ok, so I’m new here but have been around this site for a while , I have a 1995 land cruiser with a 4BTA the aftercooler routing is setup strange , I picked this project up from someone else . One of the lines from the aftercooler comes out under cylinder 1 next to the T stat housing and routes...www.4btswaps.com
Here is a link to another thread with a lot of info
Well that answers a few questions. I have a port right above the water pump on the oil cooler side I can tap in to and then return on the head. I was going to go aftermarket to save some room.![]()
