1 - 2 of 2 Posts
Hi recently removed my oil cooler to replace the gaskets behind it, looked up the gasket part numbers on quickserv and ordered them. Got them today and the gasket that goes on the actual oil cooler plate is different than the one that came off. Any one know which gasket is the correct one? I have the horizontal style oil filter.
Thanks!
The gaskets in your photo are oil filter plate gaskets, not the one that goes behind the oil cooler.The oil cooler gasket is probably part 3942914 which has a newer number 4932124. See photo below. What is you engine serial number? Sort of curious why you got 2 or the filter plate gaskets. The one on the right is for a standard "B" series engine. The one on the left is for engines with the STORM block which started around 1998. The oil filter plates for those 2 gaskets have passages in different arrangements. Here is a diagram that show the later gasket setup.
1 - 2 of 2 Posts
