been doing some searching and found that the 6bt came with a vacuum pump. now im wondering if this unit would bolt to a 4bt? im guessing it would and im guessing you kneed a differnt one for the 4bt with the bosh p7100 vs the ones with the ve pumps? do these things create enough vacuum to run a brake booster and heater controls?
now im also wondering if they make a air compressor for the b series engines? i remember back in the day when riding with my dad in the Kenwerth with the cummins he had a air compressor to run the brakes. not that i wan to run my brakes on it, jsut wondering if i can have a compressor to air up tires and run air tools.
also looking at ebay came across rebuild kits. they said they came with piston and rebore kit? i know the big rig engines can have the piston selves replaced. but can the 4bt and 6bt have that to? i thought they were cast like a normal gas engine?
how much boost can a 4bt safely take before i kneed to oring it? would it be a good idea to put a 6bt turbo on the 4bt?
