Cummins Cpl 858 Starter Cross Reference P30 Chevy And Ford
NOTE: THE STARTER FROM CUMMINS IS USUALLY THE MOST EXPENSIVE ONE
Cummins 4BT CPL858 Starter Cross References:
Starter, Nipondenso, Cummins 3904466, Nipondenso
Starter cross reference numbers:
Bosch SR9948X
Case 104452A1, 104452A2R, 1987559CI, 1987586C1, A170745, A170746, A181056
Cummins 3604485RX, 3604660RX, 3675154RX, 3904466, 3920403, 3920643, 3926960, 3957594
Delco 10461636, 10465532, 10465533, 10465540
Denso 128000-0210, 128000-0211, 128000-0212, 128000-0213, 128000-0214, 128000-0215, 128000-0216, 128000-0540, 128000-0541, 128000-0542, 128000-0543, 128000-0544, 128000-0545, 128000-2270, 128000-2271, 128000-2272, 128000-2273, 128000-2480, 128000-3120, 128000-3121, 128000-3122, 128000-3123, 128000-9500, 128000-9501, 128000-9502, 128000-9503, 228000-0620, 228000-0621, 228000-0622, 228000-0623, 228000-1950, 228000-1951, 228000-1952, 228000-1953, 228000-4670, 228000-4671, 228000-9100, 9712809-021, 9712809-950
Dixie S8254, S8299, S8534
International Truck 1308066H91, 1987559C1
Kubota 15461-63015
The P30 Chevy starter may be listed as an industrial equipment type. This starter is used with both automatic and manual Ford and GM transmission-flywheel- adapter sets found in P30 4BT retrofits.
