Hello,
Has anybody put an AX15 behind a 4bt? Success? Failure? Incredible exploding gear mess?
Would you do it?
Jeep has a NP231 xfer case, so I know I can clamp a NV4500 transmission on it. That said - do you know if the NV4500 and the AX15 are even remotely the same length? If not, is it possible to compensate for this?
The donor vehicle is a 1990 Jeep Cherokee 6cyl 4.0.
Thanks.
Would you do it?
Thanks.
