Took my 9mm early injectors down to OFI, The initial estimate was $60 each, then the update was that they were a high flow tip, tip alone was $60 and total bill will be under $400. I don't have a problem with that if that is the way to go. I asked about other injectors to replace those and the tech who was very helpful said that I need to stick with these or I can cause more problems. 7MM weren't available with the same characteristics. I had a desceptancy on my pump #'s I wrote down so I am going to verify this before going further just to make sure they are the right ones for that pump.. FWIW one was shot and the others were on their way out.
Secondly he said my pump would cost a little over $800 to rebuild vs. $650ish because of the aneroid... Does that seem right? My pump is obsolete too- no reman available so they'd rebuild it for a reman price. Any thoughts? Just buy the $26 seal kit? Governor spring and throttle plate while I'm in there?
I plan on staying stock for now, maybe an IC later.
