Hi all, I have recently got to the point on my Ram Charger with 4bta a Dodge 46RE trans 2WD where I can start driving it and I have a problem. I have no boost at any load. The engine starts fine, idles well even seems to run okay. I am only getting a little over 20 mpg and I have no boost. I have checked lift pump pressure and flow, turbo has the correct amount of clearance. I have removed the air cleaner piping. I am going to check valve clearance and injection pump timing. The truck has a 3" exhaust with a diesel muffler. I would greatly appreciate any ideas or suggestions.
