1 - 3 of 3 Posts
Putting a 2000 model 4JB1 industrial engine from a bobcat into a 98 Trooper
Engine doesnt have a normal flywheel for a 5 speed trans, some odd connection I am sure for the bobcat, in any event I have been looking for a 4JB1 flywheel but cant find one,
I did find a listing on ebay for "ISUZU D-MAX RODEO 2.5 16V SINGLE TURBO DIESEL 4JK1 SOLID FLYWHEEL 2006-2012" for decent price.
From what I have researched it will bolt onto the crank hub, but it is 10mm total larger, the clutch that is, not sure on the flywheel O.D.
Any input would be appreciated.
I think the starter ring would need checked for gear mesh. Clutch I don't see too many issues, just use a clutch diaphragm cover intended for the 4JK1 and check the 4JK1 pressure plate fits your gearbox splines. Check pilot bearing diameter too.
1 - 3 of 3 Posts
