1 - 20 of 247 Posts
Here is what I start with.
And this is what I will put in it.
I like. When you starting the build?
Well I have a little bit done now, the tear down, you know the easy part.
Test fire first on stand. with water.
This turbo is what it came with, tag beat off, You know its a winner.
Got a little bit done last nite.
The usual fix KDP
Wrong gasket
Discussion Starter #7
Stared at this for a while.
Discussion Starter #8
Home boyed seal press
Reactions: Someoldguy
Love the truck! I had a '50 3 window with a 216 and 3 speed when I was a freshman in highschool... (about 11yrs ago).. sold it cause I was dumb and broke. All original... ran and drove but needed a master cylinder... still kick myself.
Going to be watching this as I've wanted to get another one and do the same thing.
Good luck man!
-Chris
Discussion Starter #11
That's an extremely clean engine.
It was, only oily behind the ps pump, & near the oil fills. 63K miles, from Georgia area.
Some of the engines seen on here, look as if they were out of a salt mine or fertilizer plant.
Even more alarming is to see guys working on them in such nasty conditions.
Discussion Starter #12
Good luck man!
-Chris
11 years ago, you are still just a kid,you have plenty of time to be real choosey, don't get a junker, you will regret that.
I don't know what is worse, the money or the time.
Discussion Starter #13
Started the dreaded body work last nite.
Discussion Starter #14
Someone on here said to get the smallest turbo you could find, I wound up with this one
Is that an hx25? Size wise, it "looks" like it should light very quickly.
Discussion Starter #17
Discussion Starter #18
Went to the graveyard this morn, looking for parts.
Hope is running out for most of these guys.
If only I would have won that lottery 10 days ago
Discussion Starter #20
Started on the frame today, 82 chevy 1/2 ton longbed, Got to stretch it a little.
1 - 20 of 247 Posts
