201 - 220 of 247 Posts
But if you worried about your temp you can try water wetter (never tried it but heard it works.)
-vr4oaks
Reactions: oldroofer
Discussion Starter #202
-vr4oaks
I added NAPA kool 4058
Incredible work! I'd love to find a graveyard like that somewhere around me... the parts are endless! Looking forward to following this one until the end.
Discussion Starter #204
It an't gona sit around and be on welfare
We are gona work
Reactions: Russ McLean
That's what trucks were made for. Need to get busy and restore the tractor too. Always good to have a nice shiny tractor to pull behind the truck. LOL.
I dont think I realized it was a longbed. Longbeds look "RIGHT" doing a mans work. (sorry mines a shortbed-dictates of speed and donor frame)
This is a combined 10,000# load. not a 4bt but its coming... still a driver in my frito truck.
the 4.6 gas stroker does okay... that picture is at 3,000' trip was 24,000' of total elevation change in a 400 mile trip(RT)
So, how did she pull?
-vr4oaks
Discussion Starter #208
I think the tractor is fine as is
Maybe the operator needs restored
I only pulled it 10-miles in the city
Trailer brakes were not working so I didn't get crazy
Trailer weighs 3400# iirc
It went fine
Discussion Starter #209
Short beds look cartoonish to me now.
I bet the ride is fairly rough with the original gear
Same with the 1-ton, they had a large pack of springs, and additional overloads
Discussion Starter #210
Update
Update
Changed rear tires to 30"
Left pump unchanged
Pin is still to the steepest side
Road trip to Salida Colorado
Elevation from 4200 to 10500 over the divide, South of Vail & Breckenridge
Up high egt's were as high as 1320 briefly
To much smoke at low r's, Due to low boost.
Down shift, it clears up some (still too smoky for me)
A/C on
Drove max 65mph, 80 mph twice to pass semi's
Actually wound up going into Oklahoma, as there was a bridge washed out south of La Junta Co
1322.9 miles 49.9 gals= 26.51 mpg's
Discussion Starter #211
Stopped at Unimog dealer & took these
Couldn't figure this one out
Your fuel mileage is improving. Your smoke is mainly an issue of the altitude. Thinner air means the engine is going to run rich and smoke even with a turbo. I've been in Colorado 5 times with my Ford NA IDI diesels. Any time I was much above 5000' it looked like I was laying a smoke screen and the engine temp would rise to the point that the cooling fan would kick in. Once I got down into heavier air it all went back to normal. Which Unimog did you decide to take home? LOL. I don't want anything that needs a ladder to get into.
Discussion Starter #213
For those who are doing nice paint jobs,I have found out the hard way
That you need interfenders.
Bedliner or undercoating of any kind would help
A more permanent solution is interfenders
Here's mine made of 2-ply's of torchdown roofing about .25" thick
I used the existing fender bolts & made hanger brackets
Fastened front & back, Hung over others
About 7- hours labor
Reactions: Machman
Discussion Starter #214
Short road trip
Turned fuel pin to near the flattest spot
544 miles 21.56 gal = 25.23 mpg
So I lost 1.29 mpg's
Drove the same as previous
No wind for a change.
Elevation change 3100'
Egt's dropped 40-50*
Less smoke at startup
Discussion Starter #215
I have developed an problem I havn't heard of before.
After driving, when parked, on the 4th day , trany fluid leaks out of the fill tube grommet.
Where does this fluid come from?
Is this a sign the tc seal is bad?
Only 8400 miles on every thing.
There are no leaks anywhere else.
4L80E
Discussion Starter #217
I did get my 3925233 balancer installed.
It did help some, But I still have a vib. that starts at 64 mph.
At 80 mph it smooth's right out.
It seems that when I turned the pump, from, 1-turn, to 1.75 vib. worsened.
I need to turn it back down, as I'm in the 22.5 mpg range now,
and quickly get to 1300 egt.
I now have almost 12K on odometer.
Sounds like you might have a bit too much fuel. Your fuel mileage isn't terrible but I suspect you might get it up a little bit with some tuning. Probably not driving 80 MPH though. LOL. You do lose some mileage with the automatic vs a manual. The elevation where you're at can also make the engine run a bit richer which adds to the EGT.
Discussion Starter #219
When to car show, don't know how I won this. The Lincoln in the upper left was owned by Babe Ruth, he drove it only a few months, before he passed.
And I was on this years flyer.
Discussion Starter #220
Picts with a IR/Thermal imaging FLIR E5 camera
Truck at full temp, on the hot side
2Nd pict comp side
Not certain how to explain, what you see.
Maybe I will just tell lie's
