I was wondering if a GM 6.5l bellhousing for a NV4500 will bolt to the GM bell housing adapter found in a P30 bread truck w/ TH465 trans.
I have a '93 chevy 6.5l diesel (blown up) with an NV4500. My plan is to do a 4bt swap into a '97 TJ. I would like to use everything out of the truck from the engine block back. I assume all I need to do is redrill the 6.5l flywheel to the 4bt bolt pattern.
