how much total?correct, I am putting a 5600 behind my 4BT. It is massive and heavy but will be nice when done I figure.. They are expensive though...
is it true that the 5600 has an integral bellhousing? if it does did any other mfg's use the 5600 or is it possible to remove the housing?How does the NV5600 fit in most applications? From the pictures that I have seen it looks alot bigger than the NV4500. But from what I can figure it would be a bit better choice if you have the funds. I am planning on putting my 4BT in a 72 Chevy pickup and the overall size of the transmission is the big question I have.
would it be possible to to make an adapter plate to mate it to another style bell-housing?yes its true.. This is where I got burned, I heard it was integral but took a look and it is aluminum so I thought BS.. Bought a wrecked with broken bellhousing. Had to pay another $600 to have no bellhousing put on.. Then they said synchros were worn while in there, so I did a complete rebuild. I am about $3G into it all in all... Unbelieveable...
huge trans... I saw it and snapped a pic of it the other night
