4l80e High torque build
Here are some updates on my build.
I found a lot of good info on the 67-72 Chevy truck 4l80e/TH400 page that helped me alot with my tranny build. Been working on my 4l80e build and wanted to share this with yall wanting to build a stronger 4l80e.
Update on my transmission build I ordered a stage 5 kit from Jakes Performance. The superdrum that Jakes Performance sent was not what I expected. I thought I would get a custom built in house by Jakes using a stock drum with a 36 element sprag but after waiting 45+ days to receive its only a BTE TH400 drum 36 element drum that uses smaller custom intermdiate clutches that really doesn't fit 97 and up units. I decided against running it and regret ordering it.
I ordered Jakes re calibration shift kit when I placed my order. But after a lot of reading up on this I am thinking that hard shifts on a heavy truck will most likely kill the 34 element sprag and be harsh on hard parts. I decided not to run it even though Jakes said it would be fine. Instead I am going to run the stock separator plate, all accumulators and drill the 2nd, 3rd and 4th feed holes about 30% larger.
I know a lot of people on here and other sites think very highly of Jakes Performance but I am here to say it has not been a good expereince! The guy who placed my order has very little knowledge of transmission building and Jake I guess is to busy to give you a few minutes of his time to help you get what you need and not sell you things that you dont need.
My experience with TCS in Canada wasn't great as well.
I called them back about the planetary I purchased from them not having the lube slots cut in shown in their picture on their websire. Explaining that on the 1997 and up need these slots in order to lubricate the bushing and thrust bearing in the forward drum. Without these slots on a 97 and up unit the bushing and bearing would very quickly destroy their planetary, and the foward drum at a minimum.
Basically to be told they don't build transmissions and the picture is old they have sold bunches of these without lube slots with no issues and the best they can do is allow me to send it back. After studying this issue I believe that running a hollow main shaft would allow lubrication to the forward clutch bushing and thrust with out the lubrication holes. So since the Jakes performance main shaft is hollow (The Jakes performace billet main shaft was also .110 longer that the orgininal and hollow and had to be shortened to keep from it bottoming out on the input shaft)
I included a few pictures of what failed in my tranny. Evidently water had gotten in it before i bought it and rusted several parts. The thrust bearing failed on the forward clutch I believe due to rust on it. Surprizingly this thing drove for 2 years before it quit.
