1 - 6 of 6 Posts
I have a complete engine PTO air compressor system that bolts in place of the factory vacuum pump/power steering found in dodge trucks.
This includes the compressor, compressor mounting brackets, coolant lines, rear engine block coolant port, and oil line.
It also includes a used gear cover to air compressor gaskets, as well as cut fitting for all ports for reference and used bolts.
Fits on a P-Pump engine, but there is not enough room for a TPS sensor. Picture is it installed in a 1987 Chevy.
Compressor stats and part numbers:
Cust PN: 5286966RX
DATE SN: MX4517058644
SN: 5864
WABCO PN: 911154003R
Model: SS250
Water Port: 3/4" - 16 STOR
Discharge Port: M27 - 2.0 STOR
Thru-Drive: 11T
Governor Port: M10 - 1.0 STOR
Head Assembly: 9111549202X
Mounting Gasket:102368CM
The hydraulic pumps that fit between the compressor and motor mounts:
Vickers v-10F
Ford ZF Power Steering Pump F4HZ-3A674-F
Plus probably many more, but these are what I have found.
$500 +Shipping from 50701 OBO
130936
also posted on marketplace? i saw one pop up that i saved, then saw your ad here. are the major components in usable condition as far as you know?
Discussion Starter · #4 ·
Yup that was me. And yes everything is in working order. The only things needed would be a new gasket and air lines.
1 - 6 of 6 Posts
