1 - 5 of 5 Posts
OK, I've been spending lot's of time and seem to be getting nowhere in finding 6bt lift pump numbers and specs then there are so-called high performance versions of the same pumps one was claimed to be suitable for a 750 HP build and again no specs so I'm seeking input and an education on these pumps.
My build is aimed at 380-425 rear wheel HP and would like to make an "informed decision" on which mechanical pump to use.
Thanks in advance.
Your not going to get numbers or spec's of a modified performance lift pump. Period. Some people spend good money & work hard to modify, test, & re-test to come up with something better than stock.
Myself & only one other company (they sell same for much more than I do) offer a modified 30mm HVHP mechanical lift pump. Most stock piston pumps are 26mm & put out less fuel & pressure. Yes, we make claims of 700+hp because we have made that amount of power on a dyno with just this modified piston lift pump suppling the fuel. I personally have been running mine for years now. No problems, no issues.
https://shop.dieseltuff.com/Cummins-High-Volume-High-Pressure-6BT-Lift-Pump-for-P7100-HVHP-6bt-fuel-transfer-pump.htm
Best I can make out is the HVHP lift pump at 100% VE will be around 2.3 gallons/8752cc at 2600 engine rpm, the standard volume around 1.73 gals/6573cc.
My 160 HP VE is rated at 577 cc at 2600 engine rpm.
Think either of the piston pumps will cover your need.
And it's not just volume but also more pressure & fills faster & supplies faster !!!
Thanks, at least I know where to buy one now.
1 - 5 of 5 Posts
