Greetings. First time posting. I'm gearing up to attempt a Cummins 6BT swap into my motorhome. It currently has a carburetored 460 with a C6 transmission. Right off the bat everyone needs to know that I'm inspired by and following Joz's posts closely. It appears to be a similar conversion. I have 1992 1st gen, 12 valve engine coupled with a 2015 6 speed Allison 1000 from a Duramax. I am also working closely with Dave and KC from CA Conversions (CAC). They've been great. However, I am still trying to wrap my head around this conversion.
I have built a test bed to run the engine and trans combo and have figured out that a 1997 cluster works with the '92 PCM so I have all the original instrumentation. Yes, I am mounting the Dodge cluster in the Ford dash. Aux gauges will be EGT, Trans temp, Boost & Low Fuel Pressure. Currently waiting for injector pump and injectors to be rebuilt and upgraded to 230hp. Looking forward to hearing feedback and help with avoiding potential pitfalls as I take on this challenge. Will follow up with photos soon.
