1 - 2 of 2 Posts
Hello i just finished a 12 valve swap in a 92 chevy. I was wondering if anyone had any experience or thoughts to share on a possible next swap. Id be geared towards a 94 chevy 3500 crw cab 2 or 4wd long box. Id plan to use most likely a first gen powerstroke or 2nd gen with air to water intercooler make my own motor mountsand id use a zf5 trans. I know things will get expensive driveshaft will have to b fabbed and speedo n throttle pedal from ford will need to be installed and maybe a body lift? Any thoughts? Thanks
I am a 7.3 fan as I drive one everyday. I would pick up a complete donor truck to pull all the parts off of. Not sure how the crossmember will clear as the t444e has a huge pan and the 6.5s have a standard sized oil pan. I would find an obs Ford as the early 7.3s had less electronics to deal with.
1 - 2 of 2 Posts
