1972 F250 4x4, 78 d60, 3.55, np205, 200hp 4bt nv4500 in progress
Hello all, I’ve been collecting parts to transplant a 4bt and wanted to start a build thread for the benefit of others and myself since I have no background with diesel and I’ve received some good advice from others so far.
I found a package deal of a non running 4bt on a 95 dodge nv4500 drivetrain.
I’m going the long route and going through everything for reliability as I like the piece of mind knowing what I have got. Expensive education.
It was a dodge 2wd nv4500hd so to keep driveline angles better and maintain the divorced setup to the 205 I swapped the short 2wd Chevy mainshaft/housing/5th gear and went through replacing synchros and bearings using the Allstate gear kit with Koyo bearings which sound to be on par with the timken taken out. It got a new 2nd gear and dampener yoke and speedo/output bearing sleeve from torque king. I like that 5th gear issues are not an issue with this design as the yoke holds the spacer and 5th gear on. I used the 95 dodge shop manual for rebuild instructions and specs. It seemed a bit more detailed than the torque king manual which did have some good diagrams and tips.
I will get some pictures up!
