1 - 6 of 6 Posts
Detroit Section Caretaker
I don't really know anything... but I think the 903 is at least acceptable, but not considered desirable.
It's the 555 V8 "triple nickle" that's junk.
I forget the details about the 555, but supposedly in most applications it has a very short life?
Grigg
903
the 903 was a big bore V8 the up until recently has been used in the Bradley Fighting tank, over 600hp.Large in size and heavy, somewhere in the 2600+lbs....The engine was typical of the V8 design, horse power but no torque..Still a fair number running in the Midwest in Ag Tractors...It was made by Cummins and had absolutely nothing to do with Perkins....Perkins did make a V8 but it was very short lived and was by far worse than the 903...As for the 555 it was a pretty poor product but was often misapplied.....again, typical V8......no torque...
Grigg
555 was just like the Cat 3208, use them and throw them away. Dido on the "V8's have no torque." When I was in the Army the 8-wheel I drove, it wouldn't get out of it's own way until it hit 2000 RPM, then watch out.:dustin:
Just my loose change on the matter.
... up until recently has been used in the Bradley Fighting tank...
since i left the Army in '05, they still used v903t's in the Bradleys and MLRS's. and, unless there's been a real recent change, they still run them at 650hp. what have you heard they run now?
COLOJEEPGUY2K said:
...When I was in the Army the 8-wheel I drove, it wouldn't get out of it's own way until it hit 2000 RPM, then watch out...
the HEMMT's used an 8v92T ranging from 400 - 440hp, all mechanical. the PLS and HET's had DDEC versions up to 550hp. the "lack of torque" you experienced was the transmission's loose torque converter. that motor actually put out 1300ft-lbs @ 1350 rpm. the torque converter would lock-up at around 2k rpm.
1 - 6 of 6 Posts
