I am set on a manual, but not on keeping the 205. What years did getgrag and nv4500 come behind cummins? What years did the ford 6 speed zf come in fords? Does anyone know if there is a good chevy 5 or 6 speed that I can use and just adapt to the cummins, that will bolt to the 205. well actually if I get a chevy trans out of a yard I can prolly get the transfer case as well. I looked for an nv5600 but I couldnt find one under 1500.
The getrag come in 89-93 dodge trucks ,94-2001 had Nv4500 .
Gm 93 -95 used nv4500 small bolt bellhousing pattern ,won't fit Cummins dodge bellhousing.
GM 96-2000 nv4500 bolt to Cummins dodge bellhousing ,just need to swap over input parts for the dodge Nv4500 .
The gm Nv4500 will bolt to a Gm 205 if it has a 32 spline input and has a round 6 bolt pattern mid 80's and up th400 ,4l80e trucks.
The np208 will bolt up from a th400 ,or sm465 mid 's and up.
The Gm t-case came behind the Nv4500 were all IFS trucks Drivers side front diff.
The Nv5600 are big won't fit in the old style straight axle trucks without a body lift ,also they are heavy and hard to get parts for and are high $$ .
Scott
