1 - 10 of 10 Posts
hi all
Im in the process of removing a 6bt from an 89 Dodge to install in my 86 Chevy C30..
Does anyone know if i need to remove the Core Support from these vehicles to remove and install the 6bt and transmission combo?
I would hate to do this as it seems like way too much work. Thanks, Mike
I would imagine you would if you are doing both at the same time. That 6bt with the trans is awfully long!
Discussion Starter · #4 · (Edited)
Yeah, its gonna be close. I guess i wont know until i start lifting it out.
I doubt it would be one of the easier tasks as i've done a few swaps before, and removing the core support wasn't involved in any of them
It should only take about an hour to take the bumper, grill, lights, core support, radiator, and hood off. Trust me, you'll be glad you did!
I never take them off ,I always install the engine apart from the trans.
1. 90% of the time the sheet metal need to be on to know where things are going to be .
2. pain to get all the sheet metal back in place where it was .
Just me .
Scott
Just me .
Scott
Yeah, getting the body lines back in the same position can be tricky. If you're installing something that long though, you either gotta separate the Engine/Tranny or pull the front cap/core support/ no way around it really, unless you could somehow install it all from underneath (doubtful).
It MUST come off to install as a combo. It took a good while to install just the engine in mine. Basically, it is down back, down forward, push over and down another 1/2 inch....you get the picture. It is a very tight fit, but the engine will go in with the core support in. Be careful of the little hydroboost canister. I had to remove the fuel filter housing fitting to get the engine to move past it. 1/2" more clearance made a world of difference.
It's easy to remove Chevy fenders and core support as one piece. One guy on each side can lift it off and set it on the ground. I had my 79 Chevy front off probably a dozen times swapping 5 engines in and out multiple times. I only did a Ford once and that thing was very heavy and a lot more work in my opinion so the next time I took the core support out to swap a 4bt.
1 - 10 of 10 Posts
