Hey guys. Sorry I haven't been on here in awhile. I had to add a compushift controller from Baumann to control the transmission, as hard as I tried it was more trouble than it was worth to try to get the shift points lower and the TC lockup working right with the factory PCM. I still have not changed the torque converter either, the stock gm converter has had about all it can take. It started out as a 1400 rpm stall, but it is quite a bit higher now, and the TC clutch has got so bad that I have had to disable the lockup on my transmission controller because the clutches slip so bad. Otherwise we love the van, the conversion was well worth the trouble, and also everything on the van works just like factory, it is not a hack job. Btw I am really happy with the Baumann OptiShift controller as well, it was easy to install(I put it under the drivers seat), easy to program, and operates well. Thanks for taking the time to read this thread, and I hope something you have seen or read will be a help to you, if anybody has any questions just ask. God bless, Jason
