Under hood shots??........OK but its not a show truck....it gets driven 50 miles a day...to and from work.
Truck was originally diesel,I kept the chev diesel radiator and pressurized expansion tank.Currently running without an engine fan or electric fans
I put the cummins up to a Dodge NV4500 5 speed,swapped in a chevy tailshaft and tailhousing onto the dodge tranny so I could use the stock chevy transfer case. Then slid the whole engine and tranny assembly back 3inches on the chassis and redrilled the crossmember holes in the frame rails.
As for engine mounts I used the stock 92 dodge engine mounts that came on the motor and fabbed chassis mounts to suit.:smile:
The solid axle conversion allows for all the room you need to put a 6bt where it belongs.No body lift,no beating on the firewall,no crazy tilt on the motor.
I'll get more photo's of specific stuff if people ask.
Tim
